1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rough idle, Stalls, Misfire
Old May 29, 2008 | 02:18 PM
avenge98's Avatar
avenge98
Default Rough idle, Stalls, Misfire
I have a 98 avenger and the problem i am having seems to be similar to alot of others. The car starts but idles very rough smells of gasand stalls at stops. If i let the car idle in park it will continue to idle very rough. Everytime it stalls it starts back up again sometimes i have to give it gas to get it started. I have gotten the codes read by a handheld code reader and by the dealer. The codes it gives are for TPS, Misfire, map sensor. I have replaced the tps, idle air control, spark plugs and crank position sensor and nothing changed. I was told it may be the o2 sensors but i get no codes for those. Any help would be apreciated.
Old May 29, 2008 | 08:01 PM
avenge98's Avatar
avenge98
Default RE: Rough idle, Stalls, Misfire
An update on the condition... i just replaced the map sensor after taking it to the dealer and them telling me thats what it was. Did not help anything. I actually had to drive the carback from the dealer and the problem seems to be getting worse. I have to give the car gas to get it to start up and it hardly idles anymore. any help would be greatly apreciated....
Old May 29, 2008 | 08:26 PM
bad venge's Avatar
bad venge
Section Moderator
First I'd run seafoam thru the intake and gas system .... Since you've replaced a laundry list of things the few things you don't list are plug wires , distributor cap/rotor , EGR valve
Old May 29, 2008 | 11:01 PM
avenge98's Avatar
avenge98
Definatley going to try the seafoam among other things... another thing i noticed and am checking out i seem to be leaking oil. Not sure if this is related...
Old May 30, 2008 | 03:53 PM
karen_vabch's Avatar
karen_vabch
I'm having the same problem....already did full tune up, checked egr valve, all relays, even put in another computer (used one).... the car will run fine for 10 seconds then the map sensor code will come on and the engine dies. Let me know if you find anything out,.... i'm going on 2 months without my car.
