1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Front noise from axle into transmission
Old Jun 1, 2008 | 08:19 PM
Madtownvenger's Avatar
Madtownvenger
Default Front noise from axle into transmission
I had a noise like a wheel bearing around the drivers front. I pulled the wheel off, rotated the axle. The noise is comming from the point of where the axle goes into the transmission. I'm thinking there is a bearing at the transmission. It looks like it might just be bolted in there. The noise is a grinding and sounds like tin metal is slapping around too. Pretty bad noise.
So what I'm asking is there a clear cut problem? Axle or bearing in the transmission.
Thanks, it shows this is my first post, but for some reason i couldn't log on as Madtownvenge.
Thanks
Old Jun 1, 2008 | 08:36 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Front noise from axle into transmission
I'd pull the axle theres a cv joint on both ends and hope it's the axle ... the tranny might be a really expensive fix
