1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rough Idle
Old Jun 10, 2008 | 04:14 PM
joedago's Avatar
joedago
Default Rough Idle
I have a 2000 V6 Avenger. I had always noticed an intermittent shaking while the car was idling and i was sitting in it. Yesterday it has gotten worse. Seems almost like a misfire but I have no CEL light. I plan to change the plugs wires and rotor/cap on Friday. Just curious if anyone else has had this problem before I spend the $100.
Old Jun 10, 2008 | 04:48 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Rough Idle
Shaking can be a bad Idle Air Control ... Watch the RPM's do they fluctuate when the "shake" occurs ???
Old Jun 10, 2008 | 07:54 PM
joedago's Avatar
joedago
They do fluctuate a bit but barely noticable. Where is the Idle Air Control sensor located?
Old Jun 10, 2008 | 08:34 PM
bad venge's Avatar
bad venge
Section Moderator
Top of the throttle body ... I'd go get some seafoam and run it thru the intake and see if that cleans it up ...
