1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1995 avenger - CRUISE CONTROL NOT WORKING
Old Jun 14, 2008 | 12:42 PM
mrjim1965's Avatar
mrjim1965
Default 1995 avenger - CRUISE CONTROL NOT WORKING
Was still wondering if anyone knew where I could check my fuse for my cruise control????
Old Jun 15, 2008 | 08:53 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 1995 avenger - CRUISE CONTROL NOT WORKING
Must you keep asking the same questions ??? I posted the fuse box layout then asked what else is not working ??? The fuse layout has no dedicated fuse for the cruise... If the fuse is gone you will have more then that not working , check all electrical accesories , or just check all the fuses should only take 10 minutes for either ...
As mentioned before I've seen several that the switch assembly just got corroded contacts not allowing the cruise to turn on , also the light can burn out and the cruise may still work have you tried turning it on and setting it ???
Old Jun 16, 2008 | 05:04 PM
mrjim1965's Avatar
mrjim1965
I posted it again for 2 reasons, number 1 was I put my problem in the subject and second, I wanted to know if anyone else could figure out my fuse location.... Sorry
