1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Car Hopping!!!
Old Jun 29, 2008 | 07:47 AM
Sweet Avenger's Avatar
Sweet Avenger
Default Car Hopping!!!
During acceleration and deceleration my car pretty much starts to hop. If there are any suggestions please post them.
Thanksalot,
Matt
Old Jun 29, 2008 | 08:54 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Car Hopping!!!
Ok need a little more info .... tranny type automatic /stick ??? motor ???
Old Jun 29, 2008 | 10:08 AM
Sweet Avenger
Its a 5 speed and has the 4G63 engine. Its my eagle talon thats doing this.
Old Jun 29, 2008 | 10:14 AM
PappiDread6's Avatar
PappiDread6
I'm having the same problem. Does it feel like the whole car is shaking and like the engine is bouncing up and down under the hood?
My problem only happens during acceleration. Check your mounts and when was the last time you replaced your fuel pump? For some reason replacing my fuel pump fixed the problem a little, I just need to get my motor mounts now.
Old Jun 29, 2008 | 10:45 AM
Sweet Avenger
Yeah that's exactly what it feels like I was thinking it was the motor mounts but the shakin is pretty extreme. I just bought the car 3 months ago but it sat for a while before thatso it probably wont be a bad idea to change the fuel pump. I'll give it a try.
Old Jun 29, 2008 | 11:28 AM
PappiDread6
PM sent
I found it
https://dodgeforum.com/m_1151172/tm.htm
BV - suggested a bad throw out bearing.
Old Jun 30, 2008 | 12:11 PM
bad venge's Avatar
bad venge
Section Moderator
I'd check the engine /tranny mounts first ... Put the car in gear foot on brakes and rev the motor watch the motor for shifting/rocking ...
