1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Timing belt and water pump replacement
Old Jul 12, 2008 | 12:36 PM
fil327's Avatar
fil327
Default Timing belt and water pump replacement
Ok going to replace the timing belt and the water pump, my questions are this. Should I buy OEM water pump and belt or will local auto parts store parts be ok. Also is there anything els that should be replace whileIm doing this, like seals stuff like that. Thanks all.
Old Jul 12, 2008 | 04:08 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Timing belt and water pump replacement
tensioner ....A must replace ...I've seen too many fail after a new belt destroying the belt and engine
Old Jul 12, 2008 | 11:25 PM
fil327's Avatar
fil327
Ok thanks but what about the rest of the questions, should I get OEM (water pump,timing belt and Tensioner)parts or local auto parts store is ok.
Old Jul 13, 2008 | 08:44 AM
bad venge's Avatar
bad venge
Section Moderator
I've used both and not seen any difference ...
Old Jul 27, 2008 | 09:33 PM
bjpomeroy's Avatar
bjpomeroy
I bought mine from autozone. Works great.
