1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Knocking noise
Old Jul 25, 2008 | 04:52 PM
Schwanracing's Avatar
Schwanracing
Default Knocking noise
My wife drove car with oil light on for about 8 miles then it started making a knocking noise. I think it is coming from the top of motor. I took off valve cover and started car, and when i touch bearing caps on front camshaft i feel nothing but on back camshaft i can feel vibration consistant with knocking noise. (it knocks at all engine speeds) Would this be lifters? Also car has 180000 miles and if it is lifters, what else should I replace when I replace those? not sure when or if it has ever had timing belt put on.
Old Jul 25, 2008 | 04:57 PM
Schwanracing
Default RE: Knocking noise
by the way it is a 2.0
Old Jul 27, 2008 | 09:00 PM
bad venge's Avatar
bad venge
Section Moderator
PM sent ....
