1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
problem with security system
Old Aug 16, 2008 | 06:06 PM
linkbucket's Avatar
linkbucket
Junior Member
Default problem with security system
Everytime that i open my passenger door or trunk my secuity system goes off with the horn and lights flashing. I pulled the fuse for the anti theft system on the driver side but that just got rid of the horn going off and the lights still flash for a couple minutes but then go off. does anybody have any idea what causes this
Old Aug 16, 2008 | 09:12 PM
bad venge's Avatar
bad venge
Section Moderator
The passenger door pin switch is likely bad ... The trunk switch on the latch may be bent or unplugged
Old Aug 17, 2008 | 06:23 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I don't understand the problem with the alarm going off. It's supposed to do that.
Seriously though, give us the conditions of the issue. Things such as:
- the car is running
- you locked the door with key or keyfob, then opened the latch/door
- etc.
The alarm had to of been armed for the alarm to go off ever time you open the door/trunk unless you're having issues with the alarm itself. Tell us more so that we can more accurately determine the issue(s).
