1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Need Help
Old Sep 3, 2008 | 01:18 AM
venge96's Avatar
venge96
Default Need Help
Hey guys, i was driving down the road yesterday going about 45m.p.h. and all of a sudden the battery light and brake lights came on, then it felt as if the car lost power like 3 times within a second of eachother, then you could feel it go back on and jump forward. This only happend when i was accelerating, but it was fine in park and idling....i dont know what it is...i know that the battery terminals were badly corroded so i cleaned them off...haven't tested that yet....could this be the problem...???
Old Sep 3, 2008 | 10:42 AM
bad venge's Avatar
bad venge
Section Moderator
Battery terminals can cause those symptoms ... The White fusible links on the + terminal also can corrode and cause similar troubles
Old Sep 3, 2008 | 08:19 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
My thoughts are the same. Also check your alternator connections from the alt. to the fuse box, to the battery.
