1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
New some Knowledge
Old Dec 2, 2008 | 03:16 AM
avengerproject's Avatar
avengerproject
Post New some Knowledge
I have a 98 Avenger with a 420A 2.0 engine and Auto Tranny I was just wondering if its possible to swap to a Manual tranny if its possible what would it take what tranny could I use and what other things must I change? Has any one done sucha thing if so can you explain in detail what u did.
Old Dec 2, 2008 | 10:40 AM
bad venge's Avatar
bad venge
Section Moderator
Yes it's possible and as the 4 cyl came WITH a manual tranny ...
You'll need the tranny from the 4 cyl Avenger , linkages/shifter/clutch /slave cyl/pedals
and I believe the drivers side axle from it
Old Dec 2, 2008 | 08:55 PM
avengerproject
Question
Woould I need too change the TCM and the gauge cluster? Also how about the wirering harness?
Old Dec 3, 2008 | 10:40 AM
bad venge's Avatar
bad venge
Section Moderator
No on the gauge cluster ... The TCM is for the automatic .. I'm not aware of one for the manual ... I'm sure there will be wiring for the reverse switch neutral safety ect ect
Old Dec 3, 2008 | 03:34 PM
avengerproject
Default thanks
that was great help bad venge thanks 4 all the info noww im going to look for the parts needed wish me luck with this project
