1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Are my R.P.M's too high?
Old Dec 4, 2008 | 01:57 AM
candacebadie's Avatar
candacebadie
Default Are my R.P.M's too high?
I have a 96 Dodge Avenger ES V6 2.5L DOHC and on the expressway, doing about 75 m.p.h, my revs are at about 4kRPM. I wonder if this is too high because I had a 2.2L 4cyl Camry and it did 80m.p.h at about 2.8kRPM. I'm afraid that I might be hurting the engine or that this might be a sign of some kind of problem like the O/D is stuck off or it's not downshifting correctly. Any insight would be greatly appreciated!
Old Dec 15, 2008 | 06:45 AM
PappiDread6's Avatar
PappiDread6
Sorry for the last reply. Couldn't reply on DF kept loggin me off.
Short answer NO. That is why our gas mileage is so low for what power our cars produce. I know for a fact you can swap in a Dodge Neon engine for better gas mileage on the I4 engine I don't know about the V6.
Old Dec 15, 2008 | 08:44 AM
bad venge's Avatar
bad venge
Section Moderator
Not going into OVERDRIVE is the cause of the high RPM's
Old Dec 28, 2008 | 10:38 AM
Mavman's Avatar
Mavman
Default yep yep
2.7K RPM going 75 mph down the interstate.
Old Jan 13, 2009 | 03:52 PM
Darkavenger's Avatar
Darkavenger
Im running 2200 rpm doing 60 mph. around 3500 when not in overdrive.
Old Jan 14, 2009 | 04:00 AM
candacebadie
I now know that it's not going into overdrive/fourth gear. Could this be caused by a bad solenoid or is the whole transmission just shot? If the solenoid is bad, wouldn't the TCM put out a code?
