1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
lowering questions.
Old Dec 10, 2008 | 11:54 PM
BackToBlack's Avatar
BackToBlack
Default lowering questions.
i am getting the eibach pro kit for my car and have tokiko struts already, and i dont know what camber kit i should go with. if anyone else has used these springs, it would help to know about what degree camber i am looking to be off by. i dont want to get it in the car and then bring it in to get it checked cuz then i would have to wait for it to be shipped and then i would be out of a car so i want to do everything at once.... suggestions please.
Old Dec 10, 2008 | 11:58 PM
BackToBlack
and also what kind did you use. i don't know if i should go with the ball joint type.
http://cgi.ebay.com/ebaymotors/SPC-F...Q5fAccessories
or if i should use these? and i really don't see how they work.
http://cgi.ebay.com/ebaymotors/INGAL...Q5fAccessories
Old Dec 11, 2008 | 02:10 PM
bad venge's Avatar
bad venge
Section Moderator
It's near impossible to "guess" the camber ...
I've dropped venges on those same springs and the kit needed has varied from over 3 degrees to None needed for the front ...
The rear can be done withlonger bolts and spacers 1/4" per degree of correction ...
I use the ingalls as they are easier to adjust on car ....
