1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
TCM flashing?
Old Dec 14, 2008 | 11:15 PM
candacebadie's Avatar
candacebadie
Well I took it to AAMCO, where they did a trans scan and said the computer wasn't giving up any codes, then they said it would have to be either the TCM, the solenoid, or a loose connection. I figured it would be the solenoid maybe clogged since a malfunctioning TCM usually causes a second gear jam and if there was a loose wire, I don't even see how the trans would shift at all. The speedometer works fine, But I'm not sure if the solenoid for the A604 is on the outside or the inside of the transmission?
Old Dec 15, 2008 | 08:40 AM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/forum/1995-20...anny-info.html
