1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
TCM flashing?
Old Dec 11, 2008 | 01:20 AM
candacebadie's Avatar
candacebadie
Default TCM flashing?
If I had my transmission computer flashed could this help if my car is not going into fourth gear or would I have to have the trans rebuilt?
Old Dec 11, 2008 | 02:06 PM
bad venge's Avatar
bad venge
Section Moderator
First things first ....
Does the O/D light turn on /Off ???
Old Dec 11, 2008 | 07:03 PM
candacebadie
The O/D comes on/off when I hit the overdrive button on the shifter, just as it should. It's not flashing though.
Old Dec 11, 2008 | 07:48 PM
bad venge's Avatar
bad venge
Section Moderator
I was making sure you had 12 volts there ...
I doubt the tcm flashing will do anything ...
Old Dec 13, 2008 | 05:37 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
So, your car isn't able to go into overdrive then? Yeah, I don't think flashing the TCM will change that. When was the last time the fluid was changed, what color is it, are there any shiny flakes in it, and what are the RPMs and coordinating speed(s) that lead you to believe that you're not going into overdrive?
Old Dec 13, 2008 | 09:15 AM
bad venge's Avatar
bad venge
Section Moderator
That or the solenoid pack is the more likely canidates
Old Dec 14, 2008 | 06:40 PM
candacebadie
Nope, it doesn't go into overdrive. I changed the trans fluid about 2500 miles ago when I last changed the oil in order to avoid the problems that I know Chryslers are notorious for and it's still red. When the trans pan was dropped there were no gear shavings in the fluid. It shifts just fine on the streets up to about 40, but when I'm getting on the expressway and building up speed it does 60 at about 3.5krpm and does 70 at about 4.5krpm causing the cabin to be pretty loud from the engine since it doesn't go into overdrive. I got it parked now so that I don't burn up the engine or trans but according to a Chrysler tech, the final drive should engage at about 45mph and it should do 60 at 2.5krpm's
Old Dec 14, 2008 | 08:23 PM
bad venge's Avatar
bad venge
Section Moderator
Sounds like a solenoid pac trouble then
Old Dec 14, 2008 | 09:31 PM
candacebadie
Is the solenoid located on the outside or inside the transmission?
Old Dec 14, 2008 | 10:29 PM
bad venge's Avatar
bad venge
Section Moderator
I'd suggest having it CHECKED first at a tranny shop instead of blindly replacing parts ...
Your speedo does read speed ???
