1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Cylinder heads
Old Dec 29, 2008 | 04:44 PM
rdeyoe's Avatar
rdeyoe
Default Cylinder heads
Hey all!
I'm thinking of doing the 2.5 to 3.0 swap in my '95. Looks like a pretty simple swap. But....do i have to change the whole engine or can I fit the 2.5 heads to a 3.0 short block? What are the barriers? I have a 3.0 laying around already from a dodge mini-van but it has the SOHC 2 valves per cylinder heads on it. If the blocks are essentially the same, can I just bolt on the 2.5 heads with the 4 valves per cylinder?
Old Dec 29, 2008 | 05:49 PM
bad venge's Avatar
bad venge
Section Moderator
The 3.0 swap is only the listed cars in the write up the 3.0 from the mini vans do not fit and can't be adapted to the heads
Old Dec 31, 2008 | 10:49 AM
rdeyoe's Avatar
rdeyoe
Ok. So next step- will the 2.5 heads fit on the blocks of those engines in the howto?....just in case i find a short block without heads....
Old Dec 31, 2008 | 11:08 AM
bad venge's Avatar
bad venge
Section Moderator
yes ...
Old Dec 31, 2008 | 12:54 PM
rdeyoe's Avatar
rdeyoe
Thanks bad venge. After a bit of trolling around some other sites, it seems that the heads on the 2.5 and the 3.0 are identical. 'ppreciate the responses...
Old Dec 31, 2008 | 01:51 PM
bad venge's Avatar
bad venge
Section Moderator
I'm running 2.5 heads on my 3.0 ... As I already polished/ported the heads no use wasting them
