1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Prototype headlight
Old Jan 9, 2009 | 07:33 PM
bad venge's Avatar
bad venge
Section Moderator
Default Prototype headlight
http://i473.photobucket.com/albums/rr95/ba...pg?t=1231546207
Well we might finally have aftermarket projector headlights...with Halos...HID's optional
Housings can be black or Chrome
The company needs a 97+ venge for test fitment if you are in California (city of industry area ) PM me
Old Jan 9, 2009 | 11:31 PM
Rumble's Avatar
Rumble
Very cool but I don't live in cali or have a +1997 avenger (or any avenger at all)
Old Jan 10, 2009 | 12:46 AM
Mavman's Avatar
Mavman
Default question....
what is the difference in the headlights from 95/96 and 97+ that they wont interchange. Is it just the lenses or is it the whole thing. I am curious because I want euros and they say 97+ and was wondering if I could shave the lenses down or just switch them out for a 95/96
Thanks in advance for the answers
Old Jan 10, 2009 | 08:21 AM
bad venge's Avatar
bad venge
Section Moderator
The 95/96 are shorter more rounded and have small lined inscribed across the face of them .... Physically they will directly bolt in/up , the lenses will however stick out at the bottom around 1/4" , towards the middle of the car, some people have just left it ... Since these ate aftermarket no guarentee that the lenses are "swapable"... Many people just swap front ends, the 97+ has a different shape more pointed towards the middle ...
Old Jan 10, 2009 | 03:53 PM
Mavman's Avatar
Mavman
Default so if I got a set of euros.....
they would bolt it just wouldn't sit right but wouldstill bolt into the car and look okay. I was just wondering because I am getting my own fabbed in the next month and I just want to be able to use as little money as possible and get rid of those lines if I can...:Plol:P
Old Jan 10, 2009 | 04:13 PM
bad venge's Avatar
bad venge
Section Moderator
yes the bottom corner in the center is the worst , top in the center is almost flush ...
They will bolt directly up
Old Jan 10, 2009 | 04:39 PM
Mavman's Avatar
Mavman
Default anyway to.......
Fiberglass it???
Old Jan 10, 2009 | 05:04 PM
bad venge's Avatar
bad venge
Section Moderator
NO the EASIST way is to swap to a 97+ nose either a stocker or a body kit ...
Old Jan 10, 2009 | 11:44 PM
Ethan98ES's Avatar
Ethan98ES
How could you buy these headlights cause i want some?
Old Jan 11, 2009 | 10:15 AM
bad venge's Avatar
bad venge
Section Moderator
We are awaiting test fitting and once they are test fitted will be doing a group buy
