1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 avenger with sunroof
Old Jan 31, 2009 | 04:40 PM
Paulie D's Avatar
Paulie D
Default 95 avenger with sunroof
Not a common question to ask on a forum, but heres the situation. finally bought the 95 talon tsi for the parts car and about to start the swap this sprong. all i have left to do is get the avenger. since this is going to be my long term project car im being picky with it. ive been searching for a 95 avenger with a sunroof, and i finally found one. however, it is a manual sunroof. my question is did 95s comine with power sunroofs? or was that option not added until a later year. if not, is it possible to get the aftermarket manual sunroof converterd to a power sunroof? and if its done by a good shop , does it still have good chances of leaking? any knowledge on this topic would be very much appreciated asap.
thanks, Paul
Old Jan 31, 2009 | 06:44 PM
bad venge's Avatar
bad venge
Section Moderator
They never offered it as a manual ... If there is a black metal frame around it , it's aftermrket ... A good powered sunroof alone will set you back around $300/$400 just for the frame , A shop would hit you for $100/$150 labor ... And there is a better then 75% chance it will leak in the next few years
Old Feb 1, 2009 | 12:04 AM
Paulie D's Avatar
Paulie D
thanks i appreciate the quick response. would it be possible to get a powered sunroof out of an avenger in the junk yard and have that installed along with the oe switch?
Old Feb 1, 2009 | 08:29 AM
bad venge's Avatar
bad venge
Section Moderator
You'd have to cut the roof and frame out , then cut the roof out of your car then weld in the sunken roof and seal , run wire to the power roof ect , I'd say it could be done but would be very very difficult with the proper install and not warping the roof with heat welding it in
Old Feb 1, 2009 | 12:32 PM
Paulie D's Avatar
Paulie D
they did make some 95s with a power sunroof though right?
Old Feb 1, 2009 | 03:48 PM
bad venge's Avatar
bad venge
Section Moderator
ALL factory roofs were powered ... 95/00 are the same roofline/sunroof
