1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dohc or sohc?!?!?!?
Old Feb 10, 2009 | 11:26 PM
avengdriver's Avatar
avengdriver
Default Dohc or sohc?!?!?!?
Is the engine of a 1997 avenger es 2.5l v6 24valve a dohc or sohc engine
Old Feb 11, 2009 | 09:46 AM
bad venge's Avatar
bad venge
Section Moderator
Sohc with 4 valves per cylinder ...
Old Feb 17, 2009 | 09:52 AM
avengdriver
thank you, my friend did not believe me when i said my car was sohc with 24 valves
Old Feb 17, 2009 | 10:24 AM
bad venge's Avatar
bad venge
Section Moderator
It's quit common on newer engines to improve efficiency ...
Fords even took it a step further with 2 spark plugs per cylinder that fire alternately
