1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Hey ppl tranny trouble and reseting the computer
Old Feb 26, 2009 | 03:17 PM
virginatheavenger's Avatar
virginatheavenger
Default Hey ppl tranny trouble and reseting the computer
okay the tranny trouble ppl are complaning about it goin out of gear and goin back in is a ****ty selinod mine is doin the same thing and when the tranny goes into limp mode or the check engine light comes after u fix the problem all dodges and chryslers do this un hook the battery for 5 min it resets everything U know im only 20 years old and i know this when u have problems it helps to go to a local vocational school and talk to the teachers they know all these lil tricks or talk to me ill find them out i go to the college of technologies for cars i do high po and alt fuels plus general automotive so before u got out buyin new trannys test the selinoids and check the valve body inexpensive lil things
Old Feb 28, 2009 | 12:06 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you are having transmission problems, You'll need to pull codes out of the trans controller and post.
Old Feb 28, 2009 | 01:04 AM
virginatheavenger
i cant pull codes cuz guess what there is no code it doesn't throw a check engine light it just stops yes there is a computer linked to the tranny but it doesn't give u codes it just tells the transmission what to do it isn't as high tech as the new cars are so if i could get a code i would why do u think pullin the batt cables off cancels the limp mode so i think i have a lill more understanding then u do and im only 20 years old and a female and i have worked in a tranny shop so thank u very much learn about the car before u ask for codes on a car that don't have any tranny codes.
Old Feb 28, 2009 | 03:31 AM
candacebadie's Avatar
candacebadie
Red face
Well I have a 96 Dodge Avenger ES 2.5L and my transmission doesn't go into 4th gear, so on the expressway the RPM are very high past about 50mph. I took it to AAMCO and they did a trans scan and it gave up no codes. Do you have any hunches as to why it shifts just fine at low speeds but doesn't go into overdrive for fourth gear?
Old Feb 28, 2009 | 09:22 AM
bad venge's Avatar
bad venge
Section Moderator
Do you have Reverse lights ??? Dodge in their infinite wisedom tied the O/D Voltage thru the reverse light fuse / no reverse light /no voltage to the O/D circuit
Old Feb 28, 2009 | 03:43 PM
virginatheavenger
yes the reverse lights are tired to the over drive also ur button may be shorted out and it tells the car its off
Old Mar 4, 2009 | 01:52 AM
virginatheavenger
okay so has anyone ever herd of a soleniod pack b/c obviously there is a filter underneath the pack and they clog so if ur car jumbs out of gear either the pack is bad or that filter is clogged and if u need to know how to rebuild this packs send me a message and ill walk u threw this as i use to do this as a job
Old Mar 4, 2009 | 10:16 AM
master tech
Yes they do have filters, But thats all i do is just clean them. If there is a pressure circuit fault, then i replace the whole solenoid pack.
Old Mar 18, 2009 | 06:02 PM
rampag3snyper's Avatar
rampag3snyper
virginatheavenger
I got a problem with the transmission it slips gear and I did everything you said already before and it my bros car. He was working on it but stop and last year he got locked up. I'm only 17 and I don't work on cars that much I'm more of a computer guy but anyways can you help me out so that when my bro gets out he'll have it. haha
jake
Old Mar 20, 2009 | 03:54 PM
virginatheavenger
okay sweetie little lesson on tranny's usually when they slip when going into gear and tranny's are not like engines they are hard to rebuild the tranny is probley junk the clutches in there are probley fried they weren't built to handle the abuse of young ppl so i would try to get a diffrent tranny or find some one who can rebuild it
