1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Erratical Idle
Old Mar 3, 2009 | 02:37 AM
luckyvenge's Avatar
luckyvenge
Question Erratical Idle
Hey fellas I got a problem with my venge the Idle is acting weird is just some times works good but some times is goes from 8 grand to 9 grand to10 grand, back and forth I dnnt have a clue what could be causing this any Ideas (by the way I have the 2.0L engine) thanks
Old Mar 3, 2009 | 11:20 AM
Ethan98ES's Avatar
Ethan98ES
It could be a vacuum line leak maybe. That does cause the idle to jump.
Old Mar 3, 2009 | 06:24 PM
bad venge's Avatar
bad venge
Section Moderator
I'd suggest running some seafoam thru the intake tract ... That can clear the dirt out of the IAC and clear things up ... Also visually inspect all rubber hoses for cracking/dryrot
Old Mar 3, 2009 | 11:22 PM
luckyvenge's Avatar
luckyvenge
ok thanks guys, I'll try the sea foam and will also recheck the hoses. I'll let you guys know how it went.
