1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Rough Ride
Old Mar 23, 2009 | 02:37 AM
candacebadie's Avatar
candacebadie
This is more of a general purpose question, but what do oily spark plugs indicate. When removing the plugs on the car I found they were really oily on the 1st and 6th cylinder and was wondering if that indicated a more serious problem?
Old Mar 23, 2009 | 09:15 PM
bad venge's Avatar
bad venge
Section Moderator
There are O ring seals atthe bottom of the sparrk plug tubes ... Oil in the plugs can ground out the plugs and cause misses ...
You need to buy a valve cover gasket kit with the O ring seals and replace them
Old Mar 26, 2009 | 02:48 AM
candacebadie
Just letting everyone know that I finally got the car, to stop stopping on me, and smooth on out. (Crank sensor) Just waiting for my spring break so I can start on the valve cover gaskets. One more quick question, where do I pour the Seafoam so that it goes through the intake?
