1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Pos & Neg Battery Cable
Old Apr 27, 2009 | 09:30 PM
cessna2004's Avatar
cessna2004
Lightbulb Pos & Neg Battery Cable
Does anyone know where I can get a positive and negative battery cable for a 96 avenger with a v6??? The dodge dealer said they can get one for $110 but it'll take at least a week for them to get it. Thanks!
Old Apr 28, 2009 | 09:21 PM
bad venge's Avatar
bad venge
Section Moderator
Negative make your own , a trip to the audio store will get you a larger gauge wire and a ring connector to replace the stocker
the positive has multiple compononts , the white fusible links and the heavy gauge wire , what is wrong with what ???
Old Apr 29, 2009 | 12:37 PM
candacebadie's Avatar
candacebadie
Lightbulb
Just go to a parts store! (O' Reilly's, AutoZone, Pep Boys)
It'll save you the hassle of having to crimp those end fittings and rig a starter wire. And also they can tell you what length you need so that its not too long or too short. About $20 total
Old Apr 29, 2009 | 01:19 PM
cessna2004's Avatar
cessna2004
The cables are falling apart causing a short somewhere.
Old Apr 29, 2009 | 07:59 PM
bad venge's Avatar
bad venge
Section Moderator
Check the white fusible links for corrosion at the battery terminal end , I had to shorten mine up and cut out the corrosion , the same with the larger gauge + cable
Old Apr 30, 2009 | 08:32 PM
cessna2004's Avatar
cessna2004
Will do....
Old Apr 30, 2009 | 10:13 PM
jagass's Avatar
jagass
You can make negative by your own...
