1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
EGR insufficient flow detected
Old Apr 27, 2009 | 10:39 PM
Ridge's Avatar
Ridge
Default EGR insufficient flow detected
I had the CEL go on again. It started out as a misfire and ruff idle about 3 months ago. I ran some fuel system cleaner through gas tank and added a cold air intake. I also put a full can of seafoam in the tank every other fillup. It went away and runs smooth, idle is little low though. Check engine light went on couple weeks ago. Its was EGR insufficient flow deteched. Its went away after a day. Then just came back on tonight. Same code EGR insufficient flow deteched. Anyone have any guess on where to go next? or what that means?
Old Apr 28, 2009 | 11:56 AM
Killa200's Avatar
Killa200
What kind of filter is on your CAI? Also run some seafoam through the intake via a vacuum line.
Old Apr 28, 2009 | 12:21 PM
Ridge's Avatar
Ridge
K&N filter on CAI. I'm not sure where vacuum line in intake is? I've put some directly into the engine though.
Old Apr 28, 2009 | 01:07 PM
Mavman's Avatar
Mavman
take the UFO lookin part off and clean it. It may just have a clog on the vacuum line for the EGR control module that is dependent on atmospheric conditions.
Old Apr 28, 2009 | 10:02 PM
bad venge's Avatar
bad venge
Section Moderator
V6?? take the EGR off the rear of the manifold and try flushing it out , examine the piping for leaks and cracks/splitting / After cleaning no improvement replace EGR
