1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Felco 255LPH Fuel Pump
Old May 8, 2009 | 10:24 PM
nlavenge's Avatar
nlavenge
Default Felco 255LPH Fuel Pump
So heres the dumb question! what is this going to do to and for my 95 dodge avenger ES 2.5l v6???????? it is supposed to be the exact same pump as the Walbro 255lph Fuel Pump - GSS342 and all I get is a brief description nothing about EXACTLY what its going to do TO or FOR the car? please bare with me I am new to moding my car im used to VW's and pathfinders and I swore i wasnt going to do anything with my avenger but GOD I LOVE IT!! and so this is why i must ask such questions!
Old May 9, 2009 | 07:40 AM
bad venge's Avatar
bad venge
Section Moderator
Truthfully ,NOTHING ... The Larger fuel pump only allows more flow ,the Fuel pressure regulator will control that and preevent more ... IF you'd get a stand alone fuel management system and larger injectors you could tune for better power ...
The venges run pretty rich anyhow , the only way it will help is Forced inductuction/turbo/SC or the nitrous
Old May 10, 2009 | 12:54 AM
nlavenge's Avatar
nlavenge
ok so where would I start?? and what about upgrading the computer? such as af/x or some other brand would it be worth it? ultimately i want a very high performance vehicle without the use of nitrous.
Old May 10, 2009 | 01:08 AM
bad venge's Avatar
bad venge
Section Moderator
3.0 Swap ....
Old May 10, 2009 | 09:22 AM
PappiDread6's Avatar
PappiDread6
^^^ LOL! I knew you say that. It depends on what you preference is. The 3.0L V6 engine produces more base HP that the 4cly 2.0L 420A and the 2.5L V6 that come factory with our cars. But currently the V6 engines only mate to an Automatic Transmission. There is also the 4g63 2.0L swap with the potential of being All Wheel Drive.
As far as the fuel pump, I went with Walbro I never heard of Felco sounds like a Walbro rip off, but I used it because it was cheaper and performed better than OEM and I need a pump. I did feel a difference but thats because my old one was so bad.
Hey BV You know anything about the Dodge Stratus's drivetrain mating to our cars? Had one at work not too long ago looks just like ours underneath and under the hood. Seem that the crossmember was moved a little over more left tho.
Old May 10, 2009 | 09:53 PM
bad venge's Avatar
bad venge
Section Moderator
Disturbing Motorsports is doing a V6 3 speed swap ...
Old May 12, 2009 | 02:11 AM
nlavenge's Avatar
nlavenge
yea more HP is what im after having a hard time finding info on 3.0 swap though however i did see that some have gone 3.5 but again very little info, awd would be nice but i wouldnt want to downgrade to get it!
Old May 12, 2009 | 09:08 AM
mosgangstarr's Avatar
mosgangstarr
Swapping in a 4g63 is in no way a downgrade.
The 4g63 is a 2.0l turbo engine made by mitsubishi the was used in eclipse/talon.
The eclipse gst and talon tsi were both fwd and came in auto or manual.
The eclipse gsx and talon tsi awd both were awd and came with auto or manual.
Stock the motor pushes 210hp and is very well built if tuned well the stock internals can handle around 25psi of boost.
People have built motors that were pushing about 500hp on stock internals.
And btw or engine bay is identical to the eclipse/talon.
Old May 12, 2009 | 01:04 PM
nlavenge's Avatar
nlavenge
aaaaa sh*t i thought i read somewhere that the 2.5l v6 was close to 250 which i now know is wrong so i see where you guys are right now, hang with me guys im new to dodges so im still learning! while im here instead of posting new anyone know if 18" x 7.5" rims with a 5 x 4.25 or 5 x 107.95 bolt pattern and a 40 offset will work on my venge?
Old May 23, 2009 | 09:18 PM
Darkavenger's Avatar
Darkavenger
The venge has got a 5 x 114 bolt pattern
