1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Alternator Help?!
Old May 12, 2009 | 12:36 AM
pwilks24's Avatar
pwilks24
Default Alternator Help?!
I have a 2000 venge and I'm running 2x12s rockford fosgate t1s with a t1000bd and I have a kinetik hc800 battery and my battery is still getting drained and I plan on replacing my old alternator with another 110 amp one but should I get a HO alternator if possible? I don't know what other ideas there could be without the energy through my battery getting drained. PLEASE HELP!!
PS. I spoke with someone that mentioned installing a HO alternator can't be done because it can't be externally regulated which would cause the alternator to overheat in my car. I was curious if he was right and if so what should I do?
Old May 12, 2009 | 12:41 PM
Killa200's Avatar
Killa200
They make HO alts with internal and external regulators so it is possible. This is on my list of to-do's as well, because of my system and the inverter i run in the car.
Old May 12, 2009 | 02:23 PM
Killa200's Avatar
Killa200
http://search.stores.ebay.com/Iraggi...089818QQsofpZ0
Iraggi has alternators listed for the 96 - 00 chrysler sebring 2.5l, which is the same 6G73 engine as our v6. I'd have to look around more if your running a 420a
Old May 12, 2009 | 04:50 PM
pwilks24's Avatar
pwilks24
Thanks for the info! I ended up putting a 130 amp alternator in and bought another kinetik hc800 and my car is just fine. Is it possible to fit 4x12s in a avenger?
Old May 12, 2009 | 10:04 PM
bad venge's Avatar
bad venge
Section Moderator
4 is tough as they will not fit straight and the two side mounts cause cancellation
Ohio Generators made me a 180 amp unit internally regulated
