1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
throttle cable looks loose?
Old May 23, 2009 | 04:05 PM
Ridge's Avatar
Ridge
Default throttle cable looks loose?
When I took off and cleaned my egr valve I noticed that the throttle cable isn't tight. Is it supposed to be? It had a lot of give to it.
Going to have to replace the egr valve I cleaned it then CEL came back on for insufficient egr flow 2 days later.
Old May 23, 2009 | 06:45 PM
bad venge's Avatar
bad venge
Section Moderator
They stretch over time and can be adjusted
Old May 23, 2009 | 07:28 PM
Ridge's Avatar
Ridge
I assume you just tighen up the bolts going in and out of the, i think black cruise control box? right now there is like 1/2 to 3/4 inch of give pulling up and to the bottom total.
