1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
A few questions about the sound system.
Old Jun 16, 2009 | 04:42 PM
mosgangstarr's Avatar
mosgangstarr
Default A few questions about the sound system.
The other day my rear speakers went out and i'm not sure why.
I was adjusting the fade and no matter where I put the **** I only get sound from the front speakers.
The previous owner had subs that had tapped in to the wires going to the 6x9's in the rear. When I bought it the subs were out but the wires were still in there. Could they have shorted out the speakers or the amp?
When I move the speaker wires around a little I had some sound sometimes but after trying to get them in the perfect spot for a while I couldn't get any sound.
Anyone know what the problem might be and how to find/fix it?
How can I test my amp?
Does anyone know where I can get a schematic for the audio system?
Btw it's the Infinity system.
Old Jun 16, 2009 | 09:25 PM
bad venge's Avatar
bad venge
Section Moderator
The Big Connector:
2 red wires: 12v Constant (connected even when car is off! Disconnect battery before messing with!)
2 Black Wires: Grounding screw
White/black wire: Remote Turn on from HU
Input Pairs:
White/blue FL+ Black/blueFL -
White/Red FR + Black/red FR -
Yellow/Red RR + Gray/Red RR -
Yellow/Blue RL + Gray/Blue RL -
The little Connector:
All outputs to speakers
(Colors of outputs are the same as inputs)
There are two pairs of wires with the same color as the rear L/R speaker wires.
One pair, you can visibly see goes to the speakers themselves, right from the connector, the other pair goes into the big bundle, those are the front Dash L/R Speakers.
