1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 Dodge Avenger whine
Old Jun 13, 2009 | 10:57 PM
HelloBob's Avatar
HelloBob
Default 97 Dodge Avenger whine
Hi guys,
my brother has a 97 dodge avenger es (i think it's an es, it has a v6)
for some reason there is a whine that seems to come from the engine. the whine is there at idle and during acceleration. it's there as long as the engine is running. the whine can be heard from all angles of the car
i am wondering if anyone knows anything about this.
thanks
Old Jun 14, 2009 | 12:04 AM
bad venge's Avatar
bad venge
Section Moderator
I'd check the belts/tensioners first
Old Jun 14, 2009 | 12:36 PM
Killa200's Avatar
Killa200
Does it go away when the A/C is turned on or off? Mine does that right now and i figure the bearings in the magnetic clutch are about to go
Old Jun 15, 2009 | 12:03 PM
PappiDread6's Avatar
PappiDread6
Whine or groan? Turn your steering wheel from left to right a full turn both ways, Does it get louder, check your Power steering Fluid level and color should be red, unless it was changed to clear. Also when the vehicle is running check the fluid in your powersteering fluid resivior for air bubbles in the fluid.
Does it screech a start up? Belts - check for cracks, glazing, tears, parts missing or any other excessive wear.
Old Jun 16, 2009 | 10:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Pull off the V-belts and ck the idler pulley for the A/C. The bearings do go bad on these engines.
Old Jun 16, 2009 | 11:18 PM
HelloBob's Avatar
HelloBob
it is an automatic (dont know if this would any useful information, but still)
my brother says that the whine is not effected by the A/C
The noise is a whine... sounds similar to this supercharger whine at 21 seconds http://www.youtube.com/watch?v=72V8f...eature=related
Thanks for helping guys.
