1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
98 Avenger stalling
Old Aug 5, 2009 | 10:49 PM
nightrider340's Avatar
nightrider340
Default 98 Avenger stalling
OK I am a stalling problem with my 98 2.5... runs fine until you take your foot off the gas... then dies... won't start either unless you have your foot on the gas.... I also found that if I unplug any vacuum line... the car will idle and run fine... what is the vacuum line that is on the throttle body???(think it might be fuel evap) is it ok to run it with that line off??? and the car did have a bad battery.... could the relearning thing be my problem????if so how long does it take???? replaced the EGR valve a few months back... thanks Rick
Old Aug 6, 2009 | 10:47 PM
bad venge's Avatar
bad venge
Section Moderator
the IAC is normally the first cause of stalling ... I'd run seafoam thru first and formost
Old Aug 7, 2009 | 10:51 AM
nightrider340
did that too.... but ran it for a while last night with a vacuum hose disconnected.... then turned it off... then it would start.... put the vacuum line back on.... the car idles now... these things are funny
