1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
41TE transmission help
Old Aug 16, 2009 | 10:41 AM
JVenger's Avatar
JVenger
Default 41TE transmission help
I have a 2000 Dodge Avenger and wanted to see if anyone else had the same concern as I did. Whenever I shift from either reverse or drive I hear a clicking or popping noise. It also sometimes happens when I'm comming to a stop. The last thing I wanna hear is that the tranny needs to be rebuilt. I'm aware that these transmission have history of being problematic but I hope its something that can be repaired somewhat less expensive compared to buying or rebulding a transmission. Thanks in advance.
Old Aug 16, 2009 | 04:09 PM
bad venge's Avatar
bad venge
Section Moderator
IF you have the AUTO it's an A604 Tranny, and the clicking popping noise you here are the solenoid packs shifting , noise=normal
Old Aug 17, 2009 | 11:05 PM
JVenger's Avatar
JVenger
Thanks badvenge. thats one less problem to worry about for the moment
