1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
New wheels......
Old Sep 24, 2009 | 05:22 PM
Mavman's Avatar
Mavman
Default New wheels......
So I am getting rid of the 17's i have and downsizing for more dependable 16's that have more options when it comes to cheaper all whether tires. I was thinking theses.....
here
but i dont know if they will even fit on the avengers.
If anyone has some insight it would be greatly appreciated. I am looking for 16's that are gloss black and recessed due to me usually skimming the curb when I have to park in a hurry because people around here dont pay attention to other drivers. All input is greatly appreciated
Old Sep 24, 2009 | 11:03 PM
bad venge's Avatar
bad venge
Section Moderator
You need the 5 X114 onesnot the5X100's 40 offset are right
Old Sep 25, 2009 | 03:37 PM
Mavman's Avatar
Mavman
Question
both of those rims are multi supporting both the 5x100 and 5x114.3 so i thought they would. If they support the 114.3 which the avengers are they should work correct??? Also they have a note saying....
"Another important factor in correct fitments is your wheels bore size (73.1 for this custom rim). Some rim and tire packages may require an adapter (A.K.A. centering ring) in order to fit properly on your vehicle's bore. At Wheelmax, Centering rings are always included with your Wheel and Tire Package installation kit."
I was wondering if I would need to contact them or if the wheels bore size is already correct.
Info is much appreciated )
Old Sep 25, 2009 | 08:12 PM
bad venge's Avatar
bad venge
Section Moderator
The link said 5 X 100 ... It listed the others as well didn't know they are universal 5 lug ... Contact them they will send them if needed , my hubcentrics were cheesy then plastic
Old Sep 27, 2009 | 07:23 PM
cbccadet2002's Avatar
cbccadet2002
the lug pattern is correct for the avenger. But i dont know the offset specs for the car off the top of my head
Old Sep 27, 2009 | 07:30 PM
bad venge's Avatar
bad venge
Section Moderator
