1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
idle problems
Old Oct 22, 2009 | 11:03 AM
homeboysduster's Avatar
homeboysduster
Angry idle problems
i have a 98 with the 2.5 V6 when the car is cold it will idle ok. but after it warms up you can't get it to idle for nothing!!!! it throws a map code that says "map reading not changed from start to run". i replaced the map, that didn't help.changed the IAC that didn't work. replaced the maps tassel. that didn't work. full major tune up. that didn't work eather!!!!! its funny once you drive it runs like a champ! but let up off th gas and it will stall. and in order to restart it you have to peddle the gas to get it to start!!! HELP!!!!
Old Oct 22, 2009 | 09:15 PM
bad venge's Avatar
bad venge
Section Moderator
Examine the EGR if that doesn't close properly it allows in unmetered air ... quick test is to block it off in the rear of the manifold if the car idles theres the trouble
Old Oct 27, 2009 | 04:18 PM
homeboysduster
well that was it!!!! blocked off the EGR and the idle cleared right up!! it even passed a VA state inspection!!! thanks!!
Old Oct 27, 2009 | 07:08 PM
bad venge's Avatar
bad venge
Section Moderator
No Problem ... You CAN disassemble and try cleaning it , the valve seats get crapped up and doesn't seal ... Or get a new one
Old Oct 30, 2009 | 02:00 AM
Tiddy427's Avatar
Tiddy427
Question
Can you totally eliminate the EGR system in a 95 2.0L? Are there any nasty effects in the short or long term if it's done?
Old Oct 30, 2009 | 08:26 PM
bad venge's Avatar
bad venge
Section Moderator
blocking off the egr is easy ... but it can at times cause a CEL ...
Old Oct 31, 2009 | 02:28 PM
Tiddy427's Avatar
Tiddy427
Cool
What are the pros and cons of blocking that off? I can deal with a CEL as long as I'm not hurtin my baby...
Old Oct 31, 2009 | 04:45 PM
bad venge's Avatar
bad venge
Section Moderator
Really no Cons except the CEL and some never get one . more emissions
Pro's intake stays cleaner
Old Nov 1, 2009 | 01:04 AM
Tiddy427's Avatar
Tiddy427
Is there a sticky on how to do that or steps to do it anywhere? Thanks in advance...
Old Nov 1, 2009 | 08:38 AM
bad venge's Avatar
bad venge
Section Moderator
on the 2.5 I just pull the gasket/pipe off the rear and made a plug out of .... a beer can ....then reinstalled
