1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1996 Avenger Brakes
Old Nov 1, 2009 | 05:18 PM
bulktankdriver's Avatar
bulktankdriver
Question 1996 Avenger Brakes
I replaced my front brake pads, the rear calipers, and replaced the master brake cylinder. I bled the brakes and all the stuff that goes with that, and still have no brakes. My car is a 1996 Dodge Avenger 2.5 liter with ABS. Is there something about a switch or brake sensor that needs replaced?
Old Nov 1, 2009 | 06:54 PM
bad venge's Avatar
bad venge
Section Moderator
There is a SPECIFIC way to bleed ABS and if it's not followed there is air in the lines
Old Nov 2, 2009 | 07:36 AM
bulktankdriver
Thank you for a quick reply. Is there already a thread on how to properly bleed the Avengers ABS system? If not, what are the steps that it entails?
Old Nov 2, 2009 | 07:50 PM
bad venge's Avatar
bad venge
Section Moderator
I took mine off years ago ... I know it's in the chiltons manuals ...
