1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help wont pass e_check
Old Nov 24, 2009 | 11:42 AM
teddykgb5023's Avatar
teddykgb5023
Exclamation Help wont pass e_check
code tells me the O2 sensor i just replaced is bad!!! what gives my NOX reading were off the chart and ideas!!???
Old Nov 24, 2009 | 11:43 AM
teddykgb5023
its a '97 es V6
Old Nov 24, 2009 | 11:48 AM
circumventor's Avatar
circumventor
nox is when mostly yall run lean. a bad o2 usualy goes lean to fatten up a rich fuel mix which gives hc and co high
Old Nov 24, 2009 | 08:10 PM
bad venge's Avatar
bad venge
Section Moderator
are you SURE you replaced the right one ??? there are 2 in each bank
Old Nov 27, 2009 | 04:29 PM
teddykgb5023
ya the same code came up
Old Nov 27, 2009 | 04:30 PM
teddykgb5023
i would know how to get to th back two anyways like 5 pounds of crap in a two pound bag
Old Nov 27, 2009 | 06:27 PM
bad venge's Avatar
bad venge
Section Moderator
If the SAME code then you either>
A) have a broken wire feeding voltage to the O2 or sensor wire from it
B) You replaced the wrong one
C) Defective sensor out of the box
Old Dec 28, 2009 | 09:40 PM
99avngr's Avatar
99avngr
Ive had this problem on another vehicle i had. I replaced all the o2 sensors. and my code kept popping up. So i figured maybe it was because i got aftermarket so i replaced them with factory o2 sensors. And still had the same problem. I was told about Emissions pass.
You can go to your auto parts stor and get some. Its about 10-15$. What it dose is you add it to you fuel and it makes your fuel burn hotter and cleans. the motor and exaust system out. And is safe for cats, and 02 sensors. It worked wonders on my cars. I use it everytime before emissions test. And pass with flying colors
Just go in and ask for "Emissions Pass" "pt-gas " ect... there many brands but stick too those they work great hope it helps
Old Dec 29, 2009 | 10:10 AM
92dak5.24x4's Avatar
92dak5.24x4
Alcohol does the same thing and it's cheaper.
Old Dec 30, 2009 | 08:46 AM
99avngr's Avatar
99avngr
yeah im pretty sure thats what it basically is. But it works great
