1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Brake Rotors removal help
Old Dec 1, 2009 | 09:05 PM
fil327's Avatar
fil327
Smile Brake Rotors removal help
1999 Dodge Avenger ES. I am having problems getting the rotors off the front, I have been reading all the creative ways to remove them. Im just trying to understand if I have to take that big screw that sits in the center off first? I have two holes on the rotors but they dont have any threads in them, I have banged and wacked at this thing and it just wont buge. Any ideas that may work that dont include torches? Also I sprayed WD30 on it and let it sit i hope this works, I dont want to keep banging on this thing because Im afraid I might damage something else in the process. Thanks all.
Old Dec 1, 2009 | 09:28 PM
bad venge's Avatar
bad venge
Section Moderator
no the center nut holds the axle not the rotor///
A large three armed gear puler and an impact wrench usually will break them loose
