1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dodge Stratus r/t 3.0L intake manifold on 2.5L?
Old Dec 7, 2009 | 09:39 PM
v6avenger09's Avatar
v6avenger09
Question Dodge Stratus r/t 3.0L intake manifold on 2.5L?
Can I put the mitsubishi 6g72, 3.0L intake manifold from a stratus r/t on my 2.5L 6g73 Avenger? It looks pretty similar. Has anybody done this?
Old Dec 7, 2009 | 09:46 PM
bad venge's Avatar
bad venge
Section Moderator
the 3.5 manifold swap is supposed to yeild more gains larger TB ect
The 3.0 is near identical
Old Dec 7, 2009 | 10:11 PM
v6avenger09
what engine is the 3.5, mitsubishi or chrysler? and what cars have it? is it an easy swap where i can just bolt it in and connect the wires/intake?
AND,
the 3.0 intake manifold will work for sure? is that an easy swap?
Thanks again
Old Dec 7, 2009 | 10:32 PM
bad venge's Avatar
bad venge
Section Moderator
there is no advantage on the 3.0 manifold swap ... it uses the same TB///
A manifold spacer from Cheetah provides a better performance/longer runners and heat isolation
The 3.5 is a whole lot of fabrication and work.the gains come from larger TB and longer runners I'm waiting for complete info before I try this one , folks are having troubles yet
Old Dec 7, 2009 | 10:46 PM
v6avenger09
The only reason i want the 3.0L is because it is eaiser to get at the junkyard i go to because the avengers there have really bad front end crashes. there is a stratus with a 3.0L that will be eaiser to get. I plan on painting it chrome red with metalcast, not for performance. i dont want to have to worry about it being off my car and unable to drive, i just want to take my time, otherwise i would just use my 2.5 manifold. So the 3.0 is the same as the 2.5 and i can just bolt it in and connect it up?
i plan on doing the valve covers too. will the 3.0 L ones also work?
thanks again bad venge.
Old Dec 8, 2009 | 08:38 PM
bad venge's Avatar
bad venge
Section Moderator
the 3,0 swap uses the 2,5 manifold ... I don't believe that the 3,0 fits
