1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
96 Avenger has a mind of it's own
Old Jan 2, 2010 | 12:30 PM
varmintjcl's Avatar
varmintjcl
Default 96 Avenger has a mind of it's own
What would cause the loud whirring noise in the drivers door near the door handle when turning the key off & on?
Old Jan 2, 2010 | 05:44 PM
bad venge's Avatar
bad venge
Section Moderator
stuck lock actuator , oir power windows are the only thing in there ...
rear of the door(under the back seat) is the fuel pump that might radiate and sound by the door
Old Jan 2, 2010 | 09:10 PM
varmintjcl's Avatar
varmintjcl
its definitely in the door, so is there any fix for the actuator or does it have to be replaced & is it tough to get out?
Old Jan 2, 2010 | 09:25 PM
bad venge's Avatar
bad venge
Section Moderator
easy to remove inner door panel and remove it ...
