1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 2.5L transmission wont shift into overdrive.
Old Jan 18, 2010 | 05:38 PM
v6avenger09's Avatar
v6avenger09
Default 1997 2.5L transmission wont shift into overdrive.
I have a 1997 Dodge Avenger ES that wont shift into overdrive, 4th gear. My RPMs are about 2.2 grand at 40 MPH, and 3.5 grand at 60. When the O/D switch is in the off position, the O/D off light doesnt light up. Also when driving, I can push the button on and off and nothing happens. Is it something electrical?
Old Jan 19, 2010 | 12:22 PM
92dak5.24x4's Avatar
92dak5.24x4
I could be electrical and it could be internal. The only way to truely determine this is with a quality scan tool and read transmission (not pcm) codes, CVI values and data stream.
Old Jan 19, 2010 | 07:02 PM
bad venge's Avatar
bad venge
Section Moderator
Do your reverse lights work ???
If not check the fuse that fuse supplies power for the O/D switch
Old Jan 20, 2010 | 10:10 AM
v6avenger09
Yes, my reverse lights do work.
Old Jan 20, 2010 | 05:34 PM
bad venge's Avatar
bad venge
Section Moderator
check the red wire on the OD switch for 12 volts
Old Mar 15, 2010 | 12:33 AM
hiji's Avatar
hiji
hmmmmmmmmmmmmmm nice
Old Mar 17, 2010 | 02:23 AM
virginatheavenger's Avatar
virginatheavenger
do u have a local vocational school with automotive they should have a newer snap on scan tool and all the hook ups for ur car they can read trans codes and tell you what comes up and most codes can be looked up on the internet
Old Mar 6, 2013 | 09:21 PM
derrik70394's Avatar
derrik70394
Default 1997 avenger es wont go into overdrive
hey my 97 has the same prob but when i push the o/d buttonit it revs and drops a gear like it should but its not shifting into 4th, at 45 im doing excactly 2k on the tach 60 im at around 25k/3k and my reverse lights dnt work
