1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
P0134 issues after 02 replacement
Old Feb 1, 2010 | 10:54 PM
gapp0006's Avatar
gapp0006
Post P0134 issues after 02 replacement
I recently got an P0134 and replaced the upstream O2 sensor, cleared the codes and the light popped back on the next day, same code. The old O2 sensor was pretty black, and I've been getting poor fuel mileage so its obviously running rich. However I have no idea where to start looking next, either fuel injector or fuel pressure regulator? and how you check those? (it just was repaired for a misfire the week prior).
Old Feb 2, 2010 | 07:23 PM
bad venge's Avatar
bad venge
Section Moderator
What MOTOR ???
Old Feb 2, 2010 | 08:14 PM
gapp0006's Avatar
gapp0006
2.5L V6 in a '97....my bad should have said that in the first post
Old Feb 3, 2010 | 07:28 PM
bad venge's Avatar
bad venge
Section Moderator
So the exact same code came back ??? examine the wires and plug, check for steady voltage on one pin and a changing voltage on the other
