Wife's avenger is frying throttle cables...
I'm new to this forum....my wife has raved on and on about this forum so I guess it's my turn.
My wife has a 96 Avenger ES with the 2.5 V6. I'm pretty sure that she has an electrical issue. She's completely seized 4 throttle cables (the one that goes from the pulley housing, bolts to the back of the plenum, and goes to the throttle body) in the past 10 days. We've checked the ground that goes from the back of the engine to the firewall (discovered that there was a plastic piece between the end of the ground and the firewall...the end of the ground is now behind the plastic piece). Is there any other ground on this beast and where is it? Is there anything else that can cause the throttle cable to seize? Is there anywhere that I can buy a throttle cable that won't seize? I could really use the help in getting this beast back up and running for her.....especially with the possibility of a little one on the way.
After thinking about it try this , Take a jumper cable to the - of the battery and connect it to the engine. I'm thinking you lost the engine ground and it's using the throttle cable as ground
OR you can take an ohmeter and check resistance to ground from the battery then the battery to the motor
