1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1995 Dodge Avenger Just Dies
Old Feb 14, 2010 | 03:14 PM
bbarber275's Avatar
bbarber275
Default 1995 Dodge Avenger Just Dies
I have a 95 Avenger with a 2.0 Auto.A few weeks ago I pulled in to my drive way and car just stalled and would not start.I coasted down alittle bit and started back up.Well now I will be driving and it will just stall.I have replaced all the Relays for Fuel Pump and ADS.I just installed a new fuel pump and have 40 psi when Iding.I still have the stalling problem.I do the check engine light test and keep getting error 12 (battery has been unhooked, which i did replace battery but I thought I drove it enough) then 55. I have noticed twice when it had a hickup the check engine light and battery light came on for a second.Well not the car will be just driving and die, sometimes it will start back up other times it won't.Sometime after 10-15 minutes it starts back up.I just let is idle and after 5 minutes it stalled Idling.I am thinking crank or cam sensor or the computer.How can I check them.
Old Feb 14, 2010 | 03:44 PM
97Dodge's Avatar
97Dodge
Sounds like the ignition coil is going bad.
Old Feb 14, 2010 | 03:52 PM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/forum/diy-do-...bad-venge.html
CPS testing ... written for the V6 but tests are the same voltage wise
Old Feb 14, 2010 | 06:35 PM
bbarber275's Avatar
bbarber275
Never though of a ignition coil.I have a spare one I took off a parts car.I just changed it and car has been running for 10 minutes so far just at idle.I am still going to check the cam sensor in the morning.
Old Feb 14, 2010 | 09:42 PM
Tiddy427's Avatar
Tiddy427
I just went through the same problem, I replaced both cam and crank sensors and the ignition coil and still had the same symptoms. I finally replaced the computer and haven't had a problem since. I have the 95 2.0L as well...good luck
Old Feb 15, 2010 | 03:50 PM
Killa200's Avatar
Killa200
Just did the same thing with my 97 2.5L V6 with that particular symptom you described, "I have noticed twice when it had a hick up the check engine light and battery light came on for a second.". Ended up being the ECU.
Old Feb 24, 2010 | 10:10 AM
jimharlow's Avatar
jimharlow
I have no spark in ingnition
Old Feb 24, 2010 | 10:29 AM
jimharlow's Avatar
jimharlow
thank you
Old Feb 24, 2010 | 01:42 PM
bbarber275's Avatar
bbarber275
Ok, went to junk yard and pulled a computer and I replaced the cam sensor and also had a different coil.Looks like I solved my problem.I think is was the computer, as before I used to have lights on my dash flicker all the time, and so far have not had that problem.
