1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1995 Avenger Computer Interchangable
Old Feb 15, 2010 | 07:58 AM
bbarber275's Avatar
bbarber275
Default 1995 Avenger Computer Interchangable
What numbers on the computer need to match on a 1995 Avenger.It has a 2.0 Auto in it.The numbers on the computer are.Do I need to match just the 5269658 number or both of them?I found a computer from a Eagle Talon that the 5269658 will that work?
TEH - 062500173
MCC ID - P5269658 5269658
Old Feb 15, 2010 | 10:35 AM
bad venge's Avatar
bad venge
Section Moderator
I know the 95/96 venges interchanges , I've heard mixed reviews on the talon/eclipses
Old Feb 21, 2010 | 07:27 PM
Traction Dynamics's Avatar
Traction Dynamics
Is there a interchange for the 95 ES with the 2.5? Just wondering because we are thinking hard about the 3.0 swap but would like to have a computer that we could tune with.
thanks.
Old Feb 21, 2010 | 08:08 PM
bad venge's Avatar
bad venge
Section Moderator
again 95/96 , they changed 97+ ... really not much tuning with the swap
Old Feb 22, 2010 | 09:53 PM
Traction Dynamics
Raaats!!!!!!!!!
Old Feb 23, 2010 | 06:02 AM
bbarber275's Avatar
bbarber275
OK, update on a 1995 Avenger 2.0 auto you need that year only.A 96 will not work.You can use a Talon, Avenger Seabring or Neon but it has have the same options as the car you are going to use it on.I just took then MMC ID numbers and matched them up and it worked just fine.
Old Feb 23, 2010 | 06:36 PM
bad venge's Avatar
bad venge
Section Moderator
I swapped a 95 with a 96 worked fine ,
Old Feb 24, 2010 | 01:43 PM
bbarber275's Avatar
bbarber275
I have a 96 PCM and that has 2 plugs, and my 95 just has one plug with a bolt to tighten it with.
Old Feb 24, 2010 | 04:38 PM
bad venge's Avatar
bad venge
Section Moderator
Might be early 96/versus late 96 the two plugs are normally 97+
