1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
overheating...
Old Feb 18, 2010 | 08:46 AM
boxerjl2's Avatar
boxerjl2
Default overheating...
So my car keeps overheating.. Well the guage will crawl up to hot then crawl back down.. The thermostat was said to be recently changed, I'm gonna put a new one in tonight but just curious what else cud be the problem.. I have one of the fans hooked up to run when the cars on..
Old Feb 18, 2010 | 07:25 PM
bad venge's Avatar
bad venge
Section Moderator
radiator cap ... radiator , bad water pump
Old Feb 22, 2010 | 05:58 PM
Avengercrazy's Avatar
Avengercrazy
is it over heating while running idle, or while you are driving it?
Old Apr 6, 2010 | 11:05 AM
luckyfox's Avatar
luckyfox
I actually have this same problem, although it took me a little while to realize what exactly was happening.
This model has two fans. One is constantly running to keep the engine cool during normal use, and while I'm on the highway and such... It's fine. However, they aren't quick to flip the secondary on, so the engine does -appear- to be overheating. Started freaking out, but as quickly as it raised, the second fan kicked on and pushed it right back down. It's assuming you aren't sitting, and the airflow will be sufficient. However, when idling at a light or in traffic, it has to take care of the lack of air flow.
Old Apr 6, 2010 | 08:41 PM
bad venge's Avatar
bad venge
Section Moderator
second fan is unly kicked on with the AC , I rewired mine to be on all the time
Old Apr 7, 2010 | 11:59 AM
luckyfox's Avatar
luckyfox
That's strange Venge. Because I've verified that mine comes on as a secondary, even when the AC isn't on. Once the engine starts getting warm, and the primary isn't enough, it'll turn the second one on. Hmm
