1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
engine fuse keeps blowing
Old Mar 20, 2010 | 05:11 PM
dodgedzz's Avatar
dodgedzz
Default engine fuse keeps blowing
Hello all, I own a 96 avenger es 2.5. I recently upgraded my alternator to a 260 amp one. this is to run the tvs and stereo. Every since the change my engine fuse blows about a secound or two after starting.It's the 30 amp fuse under the hood any help would be nice. Thank you.
Old Mar 20, 2010 | 06:33 PM
bad venge's Avatar
bad venge
Section Moderator
Check for corrosion on the 2 white fusible links on the + terminal.
The alternator upgrade shouldn't have anything to do with it unless you scuffed a wire on the harness ect
Old Mar 20, 2010 | 07:43 PM
dodgedzz's Avatar
dodgedzz
Thank you.I'll try that anpost back if it works or not
Old Mar 22, 2010 | 11:20 AM
Killa200's Avatar
Killa200
Off topic, but where did you get your alternator? I'm shopping around for an aftermarket to replace my OEM one now that the car is deserving of some functional upgrades (glad the avenger is finally running smooth).
Old Mar 22, 2010 | 08:20 PM
dodgedzz's Avatar
dodgedzz
thank you BV for your advice. that wasn't the problem,some of the hot wire was touching the alternator.Killa200 i got the alternator from a company call iraggi alternators mine was 476 dollars for a 260 amp but he has smaller ones i just have a huge system
Old Mar 22, 2010 | 08:24 PM
dodgedzz's Avatar
dodgedzz
By the way it's in La Vernge,TN. .His name is dominick 615-287-7991 he's a good guy,about a week and a half after I place my order it was at my door.Hope that helps
