1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Noisy lifters or Valves
Old Apr 16, 2010 | 12:55 PM
Bighuji's Avatar
Bighuji
Default Noisy lifters or Valves
So I have had ticking sounds from under the valve cover, or somewhere in that area. I have a 2000 with the sport package and I was wondering if they have mechanical lifters that could be out of adjustment?
Old Apr 16, 2010 | 10:19 PM
bad venge's Avatar
bad venge
Section Moderator
hydraulic lifters you might have restricted flow yo the head I'd try an oil flush first
Old Apr 22, 2010 | 08:19 AM
JLA74's Avatar
JLA74
I would try the oil flush as well. Depending on how many miles it might take couple trys and 1000 miles of cleaning. I have the same problem and it kind of comes and goes now. I used Lucas treatment for 500 miles, then mystery oil for another 500. It helped but not a cure but i have 140K on mine. I found out that running a heavier oil after everything is cleaned out works the best.
