1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
2000 Avenger Tranny leak
Old May 9, 2010 | 07:58 AM
bdc0923's Avatar
bdc0923
Default 2000 Avenger Tranny leak
got a leak from side tranny cover behind driver side front wheel. My question is what that cover is called and were I can get one from? Looks pretty easy to change, the cover just rusted through on me. Thanks in advance for any help you might have.
Old May 30, 2010 | 03:17 AM
matson's Avatar
matson
which engine? sounds to me like its jus an inspection plate....thats not where the leak is coming from. its more than likley coming from a seal farther up....not somethin i would recommend a rookie trying to fix on his or her own
Old May 31, 2010 | 08:02 AM
bdc0923's Avatar
bdc0923
Its the 2.5, The cover [Inspection plate] has a rust hole right at the bottom everything dry above that point. Guess I have to go to the stealership?
Old May 31, 2010 | 02:12 PM
bad venge's Avatar
bad venge
Section Moderator
stealership or junkyard
