1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Sputters when Accelerating
Old May 24, 2010 | 09:42 PM
5996laud's Avatar
5996laud
Default Sputters when Accelerating
98 Avenger 2.5 v6 auto. First of all, when the car is cold it runs great for 2 or 3 minutes. No problems, Good acceleration. After 3 minutes it will sputter or boogs down with normal acceleration. You have to let up, and then accelerate slowly to pickup speed. I have checked for vacuum leaks, blocked off the EGR cleaned the IAC and check the catalytic convertor to see if it would help. Still runs the same. Could this be a bad tamp sensor. I have a temp gauge and its working. Single wire sensor and the cooling fans are a two wire sensor and its working. After 2 or 3 days I will have a code of misfire #3. And some times it will be #2 and #3 misfire. The plugs are new. And the cap and wires are less then a year.
Old May 25, 2010 | 05:16 PM
bad venge's Avatar
bad venge
Section Moderator
I'd guess CPS especially if you have warmer temps where you live
Old May 25, 2010 | 09:41 PM
5996laud's Avatar
5996laud
Ya its hot here. Nothing like working on the car when its 90 in the shade. I had an extra CPS that tested good. I put it in when the car was still hot. It did the same thing. Don’t know if this will help. When its hot, you can hold the accelerator too the floor for 15 or 20 seconds before it will rev up when it’s in park.
Old May 29, 2010 | 12:01 AM
5996laud's Avatar
5996laud
Just hooked the timing light up and when you accelerate fast the timing light goes out and it sputters. So I change the cap and rotor and have the same problem. The timing is advancing when you accelerate slowly. Runs good at high RPM’S and when it’s cold. I have checked the CPS. So I think I will go to the junkyard and get an engine computer. What else controls spark and allows the engine to run good cold ? Could it be plug gap ?
Old May 29, 2010 | 07:46 AM
bad venge's Avatar
bad venge
Section Moderator
I'd double check the CPS it's a pretty common trouble , also didn;t you get a junkyard distributer ? thay might have went south as well the computer would be my last resort
Old May 30, 2010 | 02:08 PM
5996laud's Avatar
5996laud
I have taken your advice and changed the distributor. Went to the junkyard returned the old dis. They were having a Memorial Day sale ½ off everything. So it cost $15 for a junkyard dis and it worked this time. No more problems. I could not see any problems with the old distributor. But it’s running great now. So the old dis had some typ of a problem. Thank you, Thank you for all your help !
Old May 30, 2010 | 09:03 PM
bad venge's Avatar
bad venge
Section Moderator
Glad it fixed it , theres a CKPS sensor in the distro that might have been bad
