1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
'95 2.5L No Spark
Old May 31, 2010 | 11:07 PM
Drak's Avatar
Drak
Default '95 2.5L No Spark
Well after my previous topic, I installed a new audio system. Upon completing it, the car ran fine, for a couple of hours. When I went to start the car up, nothing. It would crank, but not start.
Reading around, this seems to be common problem. I replaced the Crankshaft sensor, still no spark. I had the distributor replaced awhile back, so i don't wanna get there yet. The timing belt is fine, I'm getting fuel (I can hear the pump) no error codes are getting spit out. No blown fuses.
My main concern, is because of installing the audio system, it could of caused this? I replaced all speakers, along with a new headunit. I did have to drill a hole (to feed a 12v line to the trunk for an amp) and the hole was located close to the Crankshaft sensor, which is why I replaced it. I'm going to replace the ASD relay tomorrow. Is there anything else that's under a ~$100 fix I should try next?
Old Jun 1, 2010 | 05:40 PM
bad venge's Avatar
bad venge
Section Moderator
fuel pump relay can be intermittant , bad ASD relay, CPS testing procedures are posted
Old Jun 12, 2010 | 10:06 AM
SACGNS's Avatar
SACGNS
ALSO check your pcm, you may have shorted it. its pretty easy to do with dodge an Chrysler
