How do I hook up the factory head unit up to this amp?
Infinity system
The amp has high level inputs
One wire for channels 1-5 and a ground wire
Based on the diagram that came with the amp I believe I need to hook the positive wire of each channel to the high level input wires then run all the negatives to the ground but I'm not sure.
Which channels should I use from the stock head unit to power it?
I already have my power remote and ground ready. I just need to know what feeds from the head unit I should use. It is the stock head unit no RCA's but my amp has high level input anyways.
Trending Topics
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Antenna Left Rear
Front Speakers 6 3/4" Doors
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Antenna Left Rear
OK well with out any rca cables the easiest way to hook this up would to get an adapter to splice into your existing wiring which would convert your standard wiring to rca cables and the run straight from there to amp. You are just wiring subs rite?
