1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
squeaking noise when going over bumps and parked.
Old Jun 16, 2010 | 10:58 AM
joshua124's Avatar
joshua124
Angry squeaking noise when going over bumps and parked.
This week i started to notice 1996 Avenger ES would make some squeaking noises when i go over bumps and bumpy roads. At first i only noticed when i go over bumps. Now i notice the noise is sometimes there when the car is running and im parked.
Also my driveway slopes down. When i Turn the car off it also makes like a squeek and bang kinda noise. To me it sounds like a loose exhaust Shaking n banging against the car.. thats the best way i can describe it. The Exhaust is not loose so i don't think thats the issue. The sound seams to come from the passenger side. Sounds like the back of the car to me but im not sure.
I dont think its the shocks because it wouldnt do that if im parked as the car isnt moving. Someone said it could be the timing belt.. but i had all the belts replaced in Sep.2009
This has really got my flustered . The sounds quite annoying and i cant figure out what it is. I took it to my mechanic however hes booked today so i have to go back tomorrow. In the mean time i want to know if anyone else has had this problem or if anyone could shed some light on what it could be.
Old Jun 16, 2010 | 12:31 PM
bad venge's Avatar
bad venge
Section Moderator
I'd check the motor tranny mounts , they might be loose and shifting
Old Jun 16, 2010 | 03:30 PM
joshua124's Avatar
joshua124
hmm ill run outside n check. Also.. this has happens since i bought the car. Theres a black box near the front passenger tire ( looking from the bottom of the car.. it makes a knocking noise.. quite annoying also. Just wondering whats in that box that could be making that noise. If i hit the box it will stop knocking for a few seconds then start again. Ill go check the mounts n report back
Old Jun 16, 2010 | 04:41 PM
joshua124's Avatar
joshua124
well i checked the mounts. All seam ok. The sound is defintely coming from the rear.. i know this because when i reverse the car out of my garage the car drops ( garage floor is a tad bit higher then the driveway is.. so i clearly hear the squeek when the rear of the car exits the garage but no squeek when the front exits the garage.
This is definitely an odd issue. Im well aware that my exhaust has some kind of hole in it somewere along the pipes ( closer to the front of the car).. as i can definitely hear it and smell the fumes.
Old Jun 17, 2010 | 03:05 PM
joshua124's Avatar
joshua124
Ok im being told the issue is the Lower control arms. They need to be replaced and apparently its going to cost big $. I know theres a lifetime recall so i called Chrysler canada. The lady took my Vin and told me the Repair was done in 2001 on my car and its not a lifetime Recall. Anyone got any ideas where to go from here?
Really dont want to spend $500+ to get this fixed when i shouldn't have to.
Old Jun 17, 2010 | 04:17 PM
bad venge's Avatar
bad venge
Section Moderator
Sorry for Canada it does seem to be a one time recall, unsure if you bring it to the states. Rock auto had the arms for about $100, then you'd have labor
Old Jun 18, 2010 | 11:14 AM
joshua124's Avatar
joshua124
well i checked out rock auto. but for the lower control arm there's a bunch of them. How do i know what one i need? I see straight ones, curved ones. It looks confusing.
Old Jun 18, 2010 | 03:43 PM
bad venge's Avatar
bad venge
Section Moderator
Did you get an estimate ??? use the part number to crossmatch
did they say they were the recalled arms ???
Old Jun 18, 2010 | 10:31 PM
joshua124's Avatar
joshua124
They didnt mention the recall. My mechanic just said hes very well aware of the avengers having the control arm problem. He also said im looking at big bucks to fix it depending on weather he can get the part or weather he has to order it from the dealer. I was told $400-$700 for parts and labour
